Hi i am having problems with my pc not seeing my usb keyboard and mouse. Both wired. I have a asus sabertooth 990fx motherboard. It was working the other day. My power switch was sticking so i fixed that then plugged usb2 and usb3 and other cables back in and now none of my usb's are working.
https://linustechtips.com/topic/741589-usb-not-seeing-usb-devices/
I had a motherboard where some of the USB ports quit working. Some motherboards have tiny on-board fuses on the USB ports, but this one didn't seem to. But, it did seem to be related to overloading the USB ports.
Anyway, I had to install a separate USB expansion card in the end.
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
I was wasnt wanting to buy one lol. Found that windows 10 updates can sometimes be the problem. I have only used the front usb2 for ages then once i turned it on today none of the usb's worked :( might have to go bue one. Tomorrow :'(
