Hi,
I want to buy a desktop that will (hopefully) be able to perform amazingly for at least the next 4 years.
Specifically, I want to buy one to play a game called Star Citizen at max settings.
I already have all my peripherals so I just want some suggestions for the tower.
If need be you can also suggest a bunch of different components for me to buy and I can build one myself if that is a better value.
In terms of spending power I'm thinking around $2,000, +/- 500 if need be.
Thanks in advance,
Ankerr
https://linustechtips.com/topic/740279-help-with-buying-a-computer/
1 minute ago, Ankerr said:
Hi,
Thanks in advance,
Ankerr
Wait. For. Ryzen.
CPU: Intel Core i7 8700
GPU: Gigabyte GeForce GTX 1070
MOBO: ASUS Z370-F STRIX
RAM: 16GB Corsair Vengeance DDR4 2133MHz
Are you sureeeeeeee you don't want to build it? No? Okay, I won't criticize you. Well, go on iBuyPower and configure one that works for you. At that budget, I can confidently say that you can afford a GTX 1080 and i7 7700k, although I would wait for Ryzen to launch before you jump the gun.
never tried to overclock before, theough it might be interesing
resolution would be 1920x1080 or better
nividia graphics
probably ryzen cpu but maybe not
no editing
not an audiophile
rgb is optional
Lan (maybe with wifi option?)
size doesnt matter
13 minutes ago, That_PC_Kid said:
 AMD or Nvidia? Intel or AMD?
that is the worst possible question to ask someone. ask about there use cases like you did and just leave that part out.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
1 minute ago, That_PC_Kid said:
I can agree but some people are die hard fans of certain companies.
no need to bring it up if they truly are they will state it in the OG post.
It's unrealistic for a PC to last for 4 years without upgrading. I would get the what meets your needs now and don't spend extra on "futureproofing".
i5-6600k (4.6) | Dark Rock 3 | MSI GAMING X 1060 6GB | 8GB DDR4 | 120GB SSD & 1TB HDD | Crystal 460x
 | Acer GN246HL 1080p 24" 144hz & Acer G246HL 1080p 24" 60hz |
PSU Tier List | PC Partpickers: US Canada Australia UK
