Overclocking problems, CPU Freeze
Go to solution Solved by done12many2,
1 minute ago, phongle123 said:
How long would you suggest it?
Also, if my BIOS is set to 1.2v but CPUID CPU-Z shows 1.234v that is fine?
I'd suggest downloading RealBench 2.44 from here and running it at least for a couple of hours.  Asus recommends 4, but 2 or more should be fine.
RealBench is great because it puts your entire system (CPU + GPU) under load at one time.  If you are barely AIDA64 stable, you will probably will not pass this so be prepared to add a bit of Vcore voltage in order to pass.
10 hours ago, phongle123 said:
So starting from stock, All I do is change the Multiplayer and the Fixed Voltage, leave everything else alone?
yes pretty much, i increase by 50mhz it run stable good, if not then bump up voltage tiny bit then continue, what cpu do you have for my 7600k i wouldnt go past 1.4v, linus and other techtubers have great guides on oc'ing here
another linus
