I want to know if there is any piece of software that can help with setting the fan speeds attached to the mobo
i have this one:http://www.gigabyte.com/Motherboard/GA-Z170-HD3P-rev-10#ov
with this bios version: F4
i don't know if it has any updates, because the website is shit and doesn't explain how to perform a bios update
first of all speedfan is shit for me and my mobo isn't registered on it so it isn't any help.
second, the bios doesn't let me tweak the voltages
final, EVERY piece of software downloadable from gigabyte's website from mobo support/utility/etc. IS SHIT and doesnt even open propery, the appcenter isn't updatable and doesn't let me startup SIV or easytune
PLEASE, if someone knows something tell me,
PS: gigabyte doesn't respond to mail and it seems complaining doesn't help
https://linustechtips.com/topic/739978-gigabyte-fan-control/
Gigabyte's fan tool sucks and ya speedfan does not work on the newer boards.
http://www.gigabyte.us/Contact   1-626-854-9338
The same guy answered and helped me after I used the gigabyte @bios tool and my PC did not boot. Then called a week later and he told me the fan tool has very little function.
Bios update
https://linustechtips.com/topic/739978-gigabyte-fan-control/#findComment-9384188
