So I think that my current router is going bad, the Ethernet works, along with the 5G wifi but nothing can get onto the 2.4G wifi band. Yes i reset it, yes, I rebooted and all that stuff and nothing is working. So I am thinking that I will just have to get a new router. I have my desktop, I do a lot of gaming on and downloading stuff so it is the primary user, then there is my parents desktop, then another Ethernet cable going to my room if need be. Then for wireless, there is my phone, my tablet. my sisters phone, and my moms laptop. Suggestions?
My rigs
Desktop CPU: Intel Xeon E5-1680 v2 @ 4.4GHz cooled by a Corsair H105 | Motherboard: Asus Sabertooth X79 | RAM: 32GB G.Skill Sniper DDR3 1600 | GPU: EVGA RTX 3080 SC3 Ultra Gaming | SSD: Samsung 860 EVO 1TB + Crutial M500 240GB + Samsung 840 120GB | HDD: Seagate Barracuda 2TB 7200RPM + WB Black 4TB 7200RPM | Case: Fractal Design Meshify C | Mouse: Logitech G402 & MX Master | Keyboard: Poker II  MX Blue & Leopold 10-key pad Box Royals | Monitor: LG 34UB88-P | Audio: Audio-Technica ATH-M50 + FiiO E5 DAC + Rode NT-USB Mini
Laptop Lenovo Yoga 720 4k Touch
https://linustechtips.com/topic/73985-router-help/
Try a different 2.4ghz channel? You can change it in the router settings.  Chose either 1, 6 or 11.
https://linustechtips.com/topic/73985-router-help/#findComment-1014136
None of them worked. I can see the network but nothing can connect to the 2.4.
My rigs
https://linustechtips.com/topic/73985-router-help/#findComment-1014185
Likely interference.  Devices ranging from microwaves to cordless phones can interfere with the 2.4 Gig spectrum.  It also doesn't help if you live in an apartment building/complex where there are a bunch of people using wireless.
Current Rig
AMD Ryzen 5900X - Asus ROG Strix X570-E Gaming WiFi 2 - 32 GB GSkill TridentZ RGB
GeForce RTX 3080 - WD Black SN850 1TB  - Lian Li O11 Dynamic XL
https://linustechtips.com/topic/73985-router-help/#findComment-1018238
Well then what do I do about the interference if that is what it is. BTW I live out of town so there isn't loads of wireless in tight quarters.
My rigs
https://linustechtips.com/topic/73985-router-help/#findComment-1018860
It may be interference?
So what do I do about the interference?
My rigs
https://linustechtips.com/topic/73985-router-help/#findComment-1018861
There's not much you can do about interference except change the channel (which you've already said you tried) and hope that the problem goes away.  Other than that, you'll have to rely on the 5 Ghz band for wireless.  If you have spectrum analysis software and hardware, go ahead and use it to see what's causing the interference.
Current Rig
https://linustechtips.com/topic/73985-router-help/#findComment-1018949
Would it still be interference even if the laptop or anything is right next to the router? And nothing in my house has really changed, I just cannot connect to the 2.4 randomly.
My rigs
https://linustechtips.com/topic/73985-router-help/#findComment-1041425
Distance from broadcast point does not diminish interference.  To try an analogy, if someone's trying to talk to you and you can't hear them because I'm screaming in your ear, moving closer is not going to get that other person's message through to you until I stopped screaming.
Current Rig
https://linustechtips.com/topic/73985-router-help/#findComment-1050757
Ok, I just do not think it is interference cuz there have been no additions to the house. It is just not working now.
My rigs
https://linustechtips.com/topic/73985-router-help/#findComment-1050762
