Hi.
I've been looking for a dac for a while. As for now, I have 2 options:
1. Get schiit modi 2 + magni 2 (local dealer, so the price is double, and uber versions are out of budget)
2. Get dac\amp combo - fostex hp-a4. Costs same as above
I don't really know which option is better, because I didn't listen to any of them.
So what's the best way to go?
Thanks.
https://linustechtips.com/topic/739254-dacamp-choise-problem/
1 minute ago, JohnnyCorporalTech said:
What about ordering them straight from the manufacturer?
http://schiit.com/
The shipping costs are high and so is possible back-shipping in case of warranty situatuion. Yes, I can save some, but it may bring up some problems later.
https://linustechtips.com/topic/739254-dacamp-choise-problem/#findComment-9377309
Just in case someone's wondering: finally got to listen both of options and hp-a4 sounds much better for me, so I got this one.
Thanks everyone for advices.
edit: actually, that's funny that 2 people responded and nobody tried to answer a question asked - which one.
https://linustechtips.com/topic/739254-dacamp-choise-problem/#findComment-9377887
Yeah, real funny. If you hadn't jumped the gun I would've recommended something cheaper.
http://schiit.com/
No. Schiit has European distributors which might have offered a better price. Too late now, though.
https://linustechtips.com/topic/739254-dacamp-choise-problem/#findComment-9379308
