How did you break it? Why is it even important to have it fixed? What goes in the slot, a GPU?
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/738936-pci-lock-broke/#findComment-9373845
my cousin tried fto install a gpu and it broke.And yes it's important beacuse i'm modding something
It's hardware that makes a machine fast. It's software that makes a fast machine slow. Craig Bruce
https://linustechtips.com/topic/738936-pci-lock-broke/#findComment-9374430
