Posted February 16, 2017 Can i plug a 3 pin case fan into CPU_OPT header? Link to comment https://linustechtips.com/topic/738819-fan-headers/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 16, 2017 yep it will work just fine. Link to comment https://linustechtips.com/topic/738819-fan-headers/#findComment-9372613 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 16, 2017 Author 1 minute ago, Electronics Wizardy said: yep it will work just fine. it won't affect any thing ? Link to comment https://linustechtips.com/topic/738819-fan-headers/#findComment-9372617 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 16, 2017 1 minute ago, LogInPoi said: it won't affect any thing ? nope, its a normal fan header. Link to comment https://linustechtips.com/topic/738819-fan-headers/#findComment-9372619 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 16, 2017 Author 1 minute ago, Electronics Wizardy said: nope, its a normal fan header. ok,thank you very much. Link to comment https://linustechtips.com/topic/738819-fan-headers/#findComment-9372624 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 16, 2017 2 minutes ago, LogInPoi said: it won't affect any thing ? Check the BIOS as this can vary between motherboards but some are a slave header to the CPU header, and just matches it where in other cases they are not controllable and only provides a full 12V power. Updated Modding FAQ Link to comment https://linustechtips.com/topic/738819-fan-headers/#findComment-9372627 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
