fan setup help needed
Solved by Totalschaden1997,
6 minutes ago, mattgg said:I am trying to install my case fans, they fit and I know which way round to put and how to install,
but I have a problem with the power ,the fans are both 3 pin and I only have on 3 pin on my motherboard
You can get use a splitter/y-cable
kasdashd ·
1
6
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
