Moving System Reserved On One Drive
Solved by Sampath,
5 minutes ago, YedZed said:Is there a way to duplicate it and then delete the old copy?
Nope but you can make a fresh install and then adjust the partition size according to your needs. You can resize your partition there. But try Ease US. You may wanna give it a shot. You can try any other third party partition tool too.
