Hello everyone, currently im running 2 x120mm ID COOLING NO12025 in the front of my Phanteks Enthoo Pro M Acrylic and i have to option to go back to the single 140mm phanteks PH-F140XP, what config would be better?
The rest of my cooling setup consist of 1x PH-F140XP in the rear as exhaust and a push pull config in a thermaltake frio
https://linustechtips.com/topic/738285-fan-setup-help/
Thats sounds good config. Or rather the most common config for air cooled build. You should include temps under load, and why you are asking if config is good or not.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/738285-fan-setup-help/#findComment-9368187
