I am looking for a replacement for my Dead motherboard in my i5 3340 System, someone told me i would be better off selling all the working parts and going with a Xeon x5650, And i need advice to actually buy it, From what i can see, there seems to be multiple types of Socket 1366 Motherboard chipsets, Which one do i need? And where is the best place to buy it?
Also, What is the best rated (Using the toms hardware power supply guide) Power supply for ~£50?
An ideal motherboard would allow a fair amount of ram (16GB+) Some PCIe slots (10GbE? or raid cards), Be ATX or EATX size (To fit in a standard rack mount case) and be cost effective.
A good cooler would be active, Quiet and good quality.
Overall budget: £400 GBP (More or less) (Needs to be complete, Though I do have DDR3 RAM)
--- Purple Prime ---
i7 8700k + Hyper 212 Evo | MSI Z370 Gaming Pro CarbonG-Skill Trident Z 3000Mhz RGB 16GB | Gigabyte Aorus GTX 1080ti
Crucial MX500 500GB | WD Black 2TB | Corsair RM850i | Fractal Design Define R4LG 27UD68-P | Logitech G502 + G910 | Windows 10 Pro
--- Proteus Server ---
AyyMD Ryzen 5 3600 | Asrock B450m Pro-4 | Crucial Ballistix Sport LT 32 GB (2 x 16 GB) | Sapphire RX570 NITRO+ 8GB
Crucial MX500 1TB + Samsung Spinpoint F4 2TB + Seagate 1TB 2.5" + 5TB iDrive  | Windows 10 Pro (Temporary)
--- Camera Stuff ---
Canon EOS 77D | Canon EF-S 18-55 f/4-5.6 IS STM | Canon EF-S 55-250 f/4-5.6 IS STM | Canon EF 50mm f/1.8 STM
Zoom H5 + XY-5
Phone - Oneplus 6T
https://linustechtips.com/topic/738064-server-parts-advice/
For £400, you can get a Xeon E5-2670 and an X79 motherboard (performs considerably better than the X5650). BTW, do you want this PC for server usage?
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/738064-server-parts-advice/#findComment-9364238
Yes, Game servers, File Server, UBNT Controller, Mumble Server. Have plenty of things lined up for it.
Zoom H5 + XY-5
Phone - Oneplus 6T
https://linustechtips.com/topic/738064-server-parts-advice/#findComment-9364244
Completely agree with @PCGuy_5960, but if you still want to get x5650. Overclock it please
EVGA SR-2 / 2x Intel Xeon X5675 4.4Ghz OC / 24GB EEC 1800Mhz OC/ AMD RX570 / Enermax Evoliution 1050W / Main RAID 0: 2x256GB 840EVO SSD / BackUp(1) Raid 5: 3x2TB WD HDD / BackUp(2) 8x2TB / Dell U2412M / Dell U2312HM
https://linustechtips.com/topic/738064-server-parts-advice/#findComment-9364248
Then you will probably be using a lot of VMs. Definitely get the E5-2670, as it has 8 cores and 16 threads! And, if you want, you can get a dual socket motherboard and get 16 cores and 32 threads.
PS. I think that I had recommended the X5650 to you, but I didn't know you could spend up to £400 on this PCxD
https://linustechtips.com/topic/738064-server-parts-advice/#findComment-9364259
The £400 Is Value of what working components i have now + Some cash that i can save up.
What Version of the 2670 are we talking about?
Zoom H5 + XY-5
Phone - Oneplus 6T
https://linustechtips.com/topic/738064-server-parts-advice/#findComment-9364267
The first! You can find one for around $50 on eBay, an absolute steal for the money. (Motherboards are a bit pricey though)
https://linustechtips.com/topic/738064-server-parts-advice/#findComment-9364274
Since i am in the UK, I can only find the E5 2650 for around £50, I did spot a V2 for 70, But its bidding and will probably go higher.
Zoom H5 + XY-5
Phone - Oneplus 6T
https://linustechtips.com/topic/738064-server-parts-advice/#findComment-9364289
Can't you order from eBay US? Because PC Parts are considerably cheaper there...
If you can't, the 2650 will work. It has 2 less cores, but is still pretty fast. (however, if you can find an X5650 for cheaper, getting the X5650 wouldn't be a bad idea...)
https://linustechtips.com/topic/738064-server-parts-advice/#findComment-9364300
Shipping to the UK is like £10+
3
I did spot two 2660 xeons for an okish price: http://www.ebay.co.uk/itm/Matching-Pair-Intel-Xeon-E5-2660-2-2GHz-20M-8GT-s-SR0KK-LGA2011-CPU-Processors/162371565949?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D20140122125356%26meid%3Dcce6520da67941f0acb15d80d6bd13e7%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D142121959304
Zoom H5 + XY-5
Phone - Oneplus 6T
https://linustechtips.com/topic/738064-server-parts-advice/#findComment-9364310
https://linustechtips.com/topic/738064-server-parts-advice/#findComment-9364318
3 minutes ago, PCGuy_5960 said:
That's a good price, especially if you can find a dual socket motherboard for an OK price...
Yeah, I can't find any for less than £200 (Which is ALOT, Seeing as i would like to get a power supply and a bit more ram into the budget)
Zoom H5 + XY-5
Phone - Oneplus 6T
https://linustechtips.com/topic/738064-server-parts-advice/#findComment-9364334
Yes, but you are getting 16 cores and 32 threads.... You can get something like an EVGA 600B and DDR3 RAM is pretty cheap on eBay right now...
https://linustechtips.com/topic/738064-server-parts-advice/#findComment-9364349
True, However by the time i get rid of these parts, those deals will probably be gone, I think i will have a better look when i actually have the money to buy the parts right away, But good advice, I will take it on and scrap the x5650 idea (Although it's a good fallback if i don't have enough money)
Zoom H5 + XY-5
Phone - Oneplus 6T
https://linustechtips.com/topic/738064-server-parts-advice/#findComment-9364367
@deXxterlab97 would flip at that PSU... xD
Better dead than Red.
Pheonix
CPU: i5 2500k @ 4.6ghz Mobo: Asrock Z77 Extreme4 RAM: G.Skill 16gb of DDR3 @ 1600mhz GPU: Gigabyte GeForce GTX 1060 6gb Extreme Gaming PSU: EVGA 700B Storage: 480GB SP SSD and a 960GB Ultra II Sandisk. Cooler: Cryorig H7 Case: Phanteks P400.
https://linustechtips.com/topic/738064-server-parts-advice/#findComment-9364449
