Hello!
I was thinking, and in my future upgrade of my current pc I would like some more color and rgb lightning. So what do you recommend buying, keep in mind that I live in Sweden where the new rgb RAM hasnt been released yet... I have gotten this far: link. I want that m7 motherboard and keyboard/mouse wont change, the soundcard is needed for my speakers system. The kaby lake is just if I feel like getting it while im buying. So what do you think? Anything you would change out for me? Isnt it so that if you have a 4-pin fan the fan color will sync the color the motherboard currently have or what is the purpose of 4-pin? I have the fractal design r5 so 140mm fans is a requirement.
//Thanks
Avve1000
Setup in Profile!
https://linustechtips.com/topic/737394-rgb-build/
Isn't the NZXT hue+ something for you? https://www.nzxt.com/products/hue-plus
My own build: RΛZΞR theme
CPU: Intel Core i5 7600K // CPU cooler: Cryorig H7 // Motherboard: MSI Z270 gaming pro carbon //
Video Card: MSI Armor gtx 1070 OC 8GB // RAM: Corsair Vengeance 16GB 3200MHz //
SSD: Samsung EVO 960 500GB // HDD: 2x WD yellow edition 2TB //
Case: NZXT H440 RAZER edition // Power Supply: Corsair RM550x //
Operating Software: Windows 10 pro 64-bit
https://linustechtips.com/topic/737394-rgb-build/#findComment-9356925
