Mic static, need some help please :)
2 minutes ago, Angelpawz said:
pretty much the title, i've been having mic static in my rode procaster, i have it through a alesis multimix 4 to the back of my pc. the gain nobs are at 12 o'clock so natural i think. any help would be lovely :)
here is an example of the static/noise
Sounds like it could be common mode noise. Try to unplug all switching power supplies around the record setup. For some real in depth info check Dave's video:
Quote or tag if you want me to answer! PM me if you are in a real hurry!
Why do Java developers wear glasses? Because they can't C#!
My Machines:
The Gaming Rig:
-Processor: i5 6600k @4.6GHz
-Graphics: GTX1060 6GB G1 Gaming
-RAM: 2x8GB HyperX DDR4 2133MHz
-Motherboard: Asus Z170-A
-Cooler: Corsair H100i
-PSU: EVGA 650W 80+bronze
-AOC 1080p ultrawide
My good old laptop:
Lenovo T430
-Processor: i7 3520M
-4GB DDR3 1600MHz
-Graphics: intel iGPU :(
-Not even 1080p
lower the windows record volume that should help.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
so i think i've found my solution, https://www.amazon.ca/dp/B00ZKM3SHK/ref=twister_B01E0S77TY?_encoding=UTF8&psc=1, this bypasses the usb and it has no static. i plugged my headphones into my front pannel and the static was gone from my headphones as well, so im thinking it will do the same if i use this to plug into my line in ^_^
