Hi guys i want ask this noob question . . Does SATA 3 is compatible with my HDD 500gb SATA 3gb/s i just bought a new motherboard but i notice that motherboard doesnt support SATA 1 and SATA 2 port so does my SATA 3gb/s works with it or should i buy a new HDD?
THANK YOU
https://linustechtips.com/topic/73708-backward-compatibility-issue-for-hdd/
Yes. All SATA standards are backwards compatible.
Personal Rig
i7 4790K | Asus Z97I-WiFi | CM 280L | Sapphire R9 290X Tri-X | Kingston ValueRAM 2 x 8GB | 128GB Samsung 840 Pro | 2TB Seagate SSHD | Seasonic Platinium 660W | Bitfenix Prodigy
So even though i use my old SATA HDD still it will work with my new MSI h87 g43 gaming mobo cuz this mobo supports SATA 3 6gb/s only? Sorry for asking this im so noob with this kind of stuff :)
Yep it will work. As long as it is SATA, it will work.
Personal Rig
Thank you so much bro u save my wallet :) . .
No problem
Personal Rig
SATA is both forwards and backwards compatible. If you were to use a SATA II drive in a SATA III port, you'd get SATA II speeds. And if you were to use a SATA III drive in a SATA II port, you'd get SATA II speeds.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
