Difference between external and internal players?
Solved by Oshino Shinobu,
If you're just using it to watch Blu-Rays, they're the same. The internal one is faster at writing from what I understand (12X writer vs the 6X on the external), but that's just between those two models, not specifically an internal/external thing.
You can get external drives that can do everything an internal drive can, the only difference is whether they're designed to be in the case or out.
