RAID 5 - Different Speed SATA
By
rustikles
in Storage Devices
in Storage Devices
Solved by TheProfosist,
The 6gbps connectors are separate from the 3gbps on intel chipsets for raid arrangements. Also I wouldnt recommend raid 5 on a intel chipset or any one that is software raid or psudo-hardware raid because your going to loose a ton if speed. If you can but a 4th drive and go raid 10 youll a get a significant speed boost and double your regundancy of raid5.
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases7 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning19
play_circle_filled
Latest From ShortCircuit:
