Maybe I'm not using the right keywords or maybe I'm looking in the wrong places but I can't find any good options for a USB hub with multiple connection types for my PC. Because my computer lives under my desk it's difficult to reach things like USB and audio ports and the front IO is limited. Any suggestions for products? I need something with at least SD card and 3.5mm audio connectivity. Preferably with some 3.0/3.1/C USB ports as well.
https://linustechtips.com/topic/736500-usb-hub-recomendations/
https://www.amazon.com/Cateck-External-Adapter-High-Capacity-MacBook/dp/B01J7JS1PA/ref=sr_1_17?ie=UTF8&qid=1486832227&sr=8-17&keywords=usb+hub+3.0+sd+audio
Another option would be to get a normal USB hub and then buy a USB to sd and USB to audio adapter.
https://linustechtips.com/topic/736500-usb-hub-recomendations/#findComment-9347925
That's a bit pricier than I was hoping. So maybe I'll consider your second solution.
https://linustechtips.com/topic/736500-usb-hub-recomendations/#findComment-9347933
USB hubs for some reason are just pricey if you get anything more then USB 2.0. My 6 port USB 3.0 hub cost $24.
https://linustechtips.com/topic/736500-usb-hub-recomendations/#findComment-9347942
I use this one.  It comes with a 3 foot long cord for the USB and the power cable and has four ports.  I can plug my keyboard/mouse and phone into it with no power issues.  Best investment I have made for peripheral type components.   The thing is you want one with EXTERNAL power other wise you run the risk of plugging multiple items in and not having the power needed to run them.  So 30 dollars isn't so bad.
https://www.amazon.com/StarTech-com-Port-USB-3-0-Hub/dp/B004DVEWH4/ref=sr_1_5?ie=UTF8&qid=1486855694&sr=8-5&keywords=startech+usb+3.0+hub
Phanteks Enthoo Elite | Intel I9 - 7900X | Asus x299 Rampage VI Extreme | MSI 1080 TI
32Gb Dominator Platinum Special Edition Blackout 3200MHz  | Samsung 960 Pro | 2x Samsung 961 Pro (Raid 0) 256Gb M.2 SSD
Samsung 850 Pro 512Gb | WD Black 4TB | Corsair AX1200i
https://linustechtips.com/topic/736500-usb-hub-recomendations/#findComment-9349745
https://www.amazon.com/gp/product/B00VDVCQ84/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
That's the one that I use on a daily basis with my mouse and keyboard plugged in. There is no discernible lag, and the hub never freezes (a surprisingly common issue when running input devices.)
Also the triple 2.1A charging ports are pretty nice to have.
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
https://linustechtips.com/topic/736500-usb-hub-recomendations/#findComment-9349894
I've got this. USB 3.0 - externally powered 7 port. With x2 2.4 A charging ports.
https://www.amazon.co.uk/gp/product/B00RXKBX74
My Rig "Valiant"  Intel® Core™ i7-5930 @3.5GHz ; Asus X99 DELUXE 3.1 ; Corsair H110i ; Corsair Dominator Platinium 64GB 3200MHz CL16 DDR4 ; 2 x 6GB ASUS NVIDIA GEFORCE GTX 980 Ti Strix ; Corsair Obsidian Series 900D ; Samsung 950 Pro NVME + Samsung 850 Pro SATA + HDD Western Digital Black - 2TB ; Corsair AX1500i Professional 80 PLUS Titanium ; x3 Samsung S27D850T 27-Inch WQHD Monitor
https://linustechtips.com/topic/736500-usb-hub-recomendations/#findComment-9354160
