Hey guys so I want to buy a new pc case that it's about 100€ and I need some help I can't decide between the
  • phanteks enthoo pro m(window)
  • Phanteks p400s(window tempered one does not exist here)
  • fractal design Define S(window)
  • corsair 400c
what do you guys think? Do you have any other suggestions?
https://linustechtips.com/topic/736487-need-help-with-pc-case/
Using the Define S right now *without* a custom liquid cooling setup and it looks very empty inside.
https://linustechtips.com/topic/736487-need-help-with-pc-case/#findComment-9347829
Yeah but like shouldnt I think in a future proof way?  I got gtx 1080 and I'm gonna buy amd ryzen IF its how the information are leaked because you know the problems and had with temperature
https://linustechtips.com/topic/736487-need-help-with-pc-case/#findComment-9347967
