"Dual" connection ?
Go to solution Solved by NTDaws,
Normally it should work.
My speakers are Logitech z506.
Imagini pentru z506
I use the green,black and orange to connect it to my pc.
But sometimes i want to connect my phone to the speakers and i have to go and take the green one and plug it in to my phone...
Can I connect my phone to the speakers with : Stereo cables to jack? and have my pc still connected(but not playing).
If yes , what would happen if I play at same time phone and pc ?
Imagini pentru Stereo cables to jack
https://linustechtips.com/topic/736477-dual-connection/
If your speakers have an input selector then you will need to change, otherwise it will work, another option is to use the Line in (Light Blue) on your PC (If it has one) and then set it to repeat the input over speakers, This does require your computer to be on however.
--- Purple Prime ---
i7 8700k + Hyper 212 Evo | MSI Z370 Gaming Pro CarbonG-Skill Trident Z 3000Mhz RGB 16GB | Gigabyte Aorus GTX 1080ti
Crucial MX500 500GB | WD Black 2TB | Corsair RM850i | Fractal Design Define R4LG 27UD68-P | Logitech G502 + G910 | Windows 10 Pro
--- Proteus Server ---
AyyMD Ryzen 5 3600 | Asrock B450m Pro-4 | Crucial Ballistix Sport LT 32 GB (2 x 16 GB) | Sapphire RX570 NITRO+ 8GB
Crucial MX500 1TB + Samsung Spinpoint F4 2TB + Seagate 1TB 2.5" + 5TB iDrive  | Windows 10 Pro (Temporary)
--- Camera Stuff ---
Canon EOS 77D | Canon EF-S 18-55 f/4-5.6 IS STM | Canon EF-S 55-250 f/4-5.6 IS STM | Canon EF 50mm f/1.8 STM
Zoom H5 + XY-5
Phone - Oneplus 6T
https://linustechtips.com/topic/736477-dual-connection/#findComment-9347698
