The graphics card is a bit weak, that mobo doesn't support overclocking, and the power supply isn't the best either. As well, will 120gb really be enough. If you'd want, you can give me your budget and I'll try to make a better list.
Also, do you need this pc soon or can it wait? AMD's Ryzen should be coming out in a month or so and it's possible it could bring down prices of CPUs, so if you can wait to see if CPU prices will drop thanks to Ryzen then you might want to do that.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/736439-my-first-build/#findComment-9347411
so many strange choices..
6600k with locked board?
that PSU is shite
low profile CPU cooler in a normal profile case?
CPU: Intel Core i5-6600 3.3GHz Quad-Core Processor  ($213.66 @ OutletPC)
CPU Cooler: Deepcool GAMMAXX 400 74.3 CFM CPU Cooler  ($24.88 @ OutletPC)
Motherboard: MSI H110M PRO-VD PLUS Micro ATX LGA1151 Motherboard  ($53.99 @ Jet)
Memory: G.Skill Aegis 16GB (2 x 8GB) DDR4-2133 Memory  ($94.99 @ Newegg)
Storage: PNY CS1311 120GB 2.5" Solid State Drive  ($49.99 @ Best Buy)
Video Card: MSI Radeon RX 480 4GB Video Card  ($184.98 @ Newegg)
Case: Cooler Master N200 MicroATX Mini Tower Case  ($44.89 @ SuperBiiz)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($50.89 @ Newegg)
Wireless Network Adapter: Gigabyte GC-WB867D-I PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter  ($29.99 @ SuperBiiz)
Total: $748.26
Generated by PCPartPicker 2017-02-11 09:16 EST-0500
changed processor to a locked one, cheaper ram, better GPU, better PSU, better case, better cooler.
OR
you can wait a month or so and get AMD's fancy new affordable Ryzen architecture. It's gon b gud
idk
https://linustechtips.com/topic/736439-my-first-build/#findComment-9347414
The core parts all seem very good.
GTX 1050ti will allow you to play any game but not at highest settings.
Will you be overclocking your CPU? If not I recommend picking an i5 6600 NON-K since your motherboard doesn't allow it.
If you want to overclock you'll have to swap for a Z170 motherboard.
Any particular reason that you picked a low profile CPU cooler?
I recommend stepping up on the PSU, 500w is plenty for this build but it's of poor quality.
A semi budget option will be the GREY labeled CXM units from Corsair.
https://linustechtips.com/topic/736439-my-first-build/#findComment-9347421
The PSU is a little bit overkill but it's fine , and that case is pretty bad. I suggest you get the corsair carbide series 100R. It's what I built my pc In. Also, i would suggest getting a hard drive to go with your SSD, beacause 120GB will run out very quickly, especially if you are getting games.
Since I am to lazy to put something interesting here, I will put everything, but slightly abbreviated. Here is everything:
42
also, some questions to make you wonder about life:
What is I and who is me? Who is you? Which armrest in the movie theatre is yours?
also,
Welcome to the internet, I will be your guide. Or something.
My build:
CPU: Intel Core i5-7400 3.0GHz Quad-Core Processor,
 Motherboard: ASRock B250M Pro4 Micro ATX LGA1151 Motherboard,
Memory: Corsair 8GB (1 x 8GB) DDR4-2133 Memory,
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive,
Video Card: MSI Radeon RX 480 4GB ARMOR OC Video Card,
Case: Corsair 100R ATX Mid Tower Case ,
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply,
Operating System: Microsoft Windows 10 Home Full,
Wireless Network Adapter: TP-Link TL-WN725N USB 2.0 802.11b/g/n Wi-Fi Adapter, Case Fan: Corsair Air Series White 2 pack 52.2 CFM  120mm Fan
ou do not ask why, you ask why not -me
Remeber kinds, the only differ between screwing around and scince is writing it down. -Adam Savage.
Only two things are infinite: the universe and human stupidity, and I'm not even sure of the former. - Albert Einstein.
https://linustechtips.com/topic/736439-my-first-build/#findComment-9347422
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($239.99 @ Jet) i7 4770 clocked 100mhz less, should help for CAD.
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($42.88 @ OutletPC)
Memory: G.Skill Ares Series 16GB (2 x 8GB) DDR3-1600 Memory  ($94.88 @ OutletPC)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  ($43.74 @ B&H)
Video Card: PowerColor Radeon RX 480 8GB Red Devil Video Card  ($223.98 @ Newegg)
Case: Fractal Design Core 1100 MicroATX Mini Tower Case  ($29.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply  ($46.98 @ Newegg)
Wireless Network Adapter: Gigabyte GC-WB867D-I REV 4.2 PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter  ($29.99 @ SuperBiiz)
Total: $752.43
Generated by PCPartPicker 2017-02-11 09:19 EST-0500
https://linustechtips.com/topic/736439-my-first-build/#findComment-9347425
that PSU is shite
Total: $748.26
OR
The PSU is not sh**, it's just budget. It's fine.
42
also,
My build:
https://linustechtips.com/topic/736439-my-first-build/#findComment-9347432
11 minutes ago, MVPernula said:
5 minutes ago, Droidbot said:
it's an okay unit for low-end HTPCs, not a goddamn explosive.
http://www.jonnyguru.com/modules.php?name=NDReviews&file=print&reid=384
https://linustechtips.com/topic/736439-my-first-build/#findComment-9347480
it's $45, S12II 520 is $50.
And there's a three tier difference. Mind you, the EVGA has a $10 USD rebate, but it depends if you'll ever see it and you still pay upfront.
idk
https://linustechtips.com/topic/736439-my-first-build/#findComment-9347488
i'm not talking about the value at all(i know that part sucked) i'm telling you that psu isn't horrible like what the 2 of you are claiming.
https://linustechtips.com/topic/736439-my-first-build/#findComment-9347575
I'm just being hyperbolic, I know it's a bit hard to tell over the internet lmao
It's not a super duper bad PSU like this
idk
https://linustechtips.com/topic/736439-my-first-build/#findComment-9347584
PCPartPicker part list: https://pcpartpicker.com/list/dqWFxY
Price breakdown by merchant: https://pcpartpicker.com/list/dqWFxY/by_merchant/
CPU: Intel Core i5-7500 3.4GHz Quad-Core Processor  ($196.43 @ OutletPC)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($55.88 @ OutletPC)
Memory: PNY Anarchy 16GB (2 x 8GB) DDR4-2133 Memory  ($99.99 @ Best Buy)
Video Card: MSI Radeon RX 480 8GB GAMING X Video Card  ($244.99 @ Newegg)
Case: Corsair Carbide Series 88R MicroATX Mid Tower Case  ($49.99 @ Corsair)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($43.88 @ OutletPC)
Total: $764.89
Generated by PCPartPicker 2017-02-11 10:11 EST-0500
Better PSU, better GPU,better case and cheaper RAM.
https://linustechtips.com/topic/736439-my-first-build/#findComment-9347596
