JPG File upload problem
Go to solution Solved by colonel_mortis,
Pasting raw images isn't supported, sorry. You need to copy the image URL, not the actual image (the image will show in the editor, but it is stripped when submitted).
-moved to bugs and issues-
I've never had any issue uploading jpgs or any other image before... can you elaborate on how this happens?
https://linustechtips.com/topic/736363-jpg-file-upload-problem/#findComment-9346728
I was trying help a person tell the difference between a CPU and Ram and I googled up pictures of a CPU and Ram sticks to show him the difference. All the JPG photo would not show up when saved it on to the fourm but on the pre page it show all the photo. I only had the problem with the JPG photo's.
https://linustechtips.com/topic/736363-jpg-file-upload-problem/#findComment-9346770
what do you mean by "saved it on to the fourm but on the pre page it show all the photo"?
https://linustechtips.com/topic/736363-jpg-file-upload-problem/#findComment-9346802
5 minutes ago, colonel_mortis said:
Are you adding the pictures to the post? Once you've dragged them into the upload zone, they appear as thumbnails, but you have to click the + to add them to the actual post body.
If you don't they automatically append to the bottom of the post though
https://linustechtips.com/topic/736363-jpg-file-upload-problem/#findComment-9346879
I just copy and past the images I only had the problem with JPG  images just did not  appear not even the links when I submitted it.
https://linustechtips.com/topic/736363-jpg-file-upload-problem/#findComment-9346905
I've never tried to insert using copy and paste, so that could be it.  What happens if you paste the link to the image, or attach it using upload?
https://linustechtips.com/topic/736363-jpg-file-upload-problem/#findComment-9346909
