2 minutes ago, XDpatrickFTW said:
In csgo 180 on low to mid 1080p
Bf1 al low 80
But always cpu 100% and gpu 80 or 90 procent
For BF1 it is normal on the MP map with 64 slots for 100%... Even the best i7 have problems. Try BF1 in SP and look at the CPU usage.
My Setup:
CPU: i7 4790 @3800 MHz, MB: MSI H87-G41, Grafik: Gigabyte GTX 1080TI, RAM: 2x 8GB DDR3 (1600), Storage: Samsung SSD 850 Evo
https://linustechtips.com/topic/735644-cpu-100-load/#findComment-9339206
That CPU should not be @ 100% load playing csgo @ 1080p. More like 50-80%.
Something is bogging your system down, spyware, viruses, recording devices, etc.
I'm not sure what GPU you have, but even the 970 paired with the i5 nets 200-300fps @ 60-80% load.
I7-7700k@5.1ghz + 1080ti @ 2050mhz + 32gbs Ram + 2TB SSD = CSGO
i7-6700k@4.9ghz + 980ti @ 1501mhz + 16gbs Ram + 1 TB SSD = Backup
i7-3770k@4.8ghz + 680 4gb + 32gbs Ram + 500gb SSD = Retired/Office work
https://linustechtips.com/topic/735644-cpu-100-load/#findComment-9339214
Il have a look yeahh my fps in is 180 on the low 230 normal but no virus scans or things like that only discord or teamspeak thats everything
https://linustechtips.com/topic/735644-cpu-100-load/#findComment-9339269
in conquest in bf1 1440p ultra 80fps my i5 7600k runnin 80%
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
https://linustechtips.com/topic/735644-cpu-100-load/#findComment-9340014
At least it is not 100% like the 6600k was.  I imagine game play is still smooth though, right?
Fractal Design Define C | Intel Core i7 7700k | Corsair H100i V2 | Gigabyte Z270X Gaming 7 | Seasonic Prime 750 | MSI GTX 1080 Gaming X
16gb G.Skill Trident Z | Samsung 960 Evo NVMe 500gb | Razer Black Widow Chroma | Razer Death Adder Chroma | Razer Firefly | Dell U2515H
https://linustechtips.com/topic/735644-cpu-100-load/#findComment-9340602
60fps is the cut off point and i only have a 60hz monitor atm so u know but ye why would it not be
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/735644-cpu-100-load/#findComment-9346081
