Hey guys so i got a new pc with a i7 6700 and I just want to know if the clock speeds I'm getting are normal for the chip. So if you have a 6700 share your clock speeds and the cooler you are using.
IDLE: 3.88 GHz
Normal load: 3.74 GHz
Heavy load: 3.61 GHz
Min Speed: 3.57 GHz
https://linustechtips.com/topic/735274-i7-6700-clock-speed/
The [load and min] clocks make no sense unless you're thermally throttling.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/735274-i7-6700-clock-speed/#findComment-9334872
1 minute ago, captainofeggrolls said:
Thermals are fine 31 c idle max 65 c
Looks fine then.
https://linustechtips.com/topic/735274-i7-6700-clock-speed/#findComment-9334893
ya and i forgot to emphysize this is the non- k version so isnt base clock 3.4
Turbo Boost
https://linustechtips.com/topic/735274-i7-6700-clock-speed/#findComment-9334894
The core clock is fine, it is just that turbo booster effect you will lose 0,1ghz per core being used so: 1 core 2 threads = 4ghz, 2 cores 4 threads = 3,9ghz, 3 cores 6 threads = 3,8ghz, 4 cores 8 threads = 3,7ghz
Sometimes if it is 100% usage and your power profile is balanced instead of high performance it can get as low as 3,5~3,6ghz
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/735274-i7-6700-clock-speed/#findComment-9334896
