I'm trying to mod a Micro-USB Type B cable for power-only, and I don't know the color coding. I searched for it, but some colors were different and I didn't want to play guess-the-colors later on.
The picture is a Google Drive link, 'should' take you there.
https://drive.google.com/file/d/0B0uC6ynm9DVJRzNwNDJSaUI3QzQ/view?usp=drivesdk
Which ones do I cut?
https://linustechtips.com/topic/735244-usb-cable-colors/
Probe the USB type A connections to ensure they are correctly wired as some don't follow color scheme, however if it is correct the Red and black should be power.
https://linustechtips.com/topic/735244-usb-cable-colors/#findComment-9334524
I wouldn't trust the colors. Need to test them.
CPU: Ryzen 5950X Ram: Corsair Vengeance 32GB DDR4 3600 CL14 | Graphics: GIGABYTE GAMING OC RTX 3090 |  Mobo: GIGABYTE B550 AORUS MASTER | Storage: SEAGATE FIRECUDA 520 2TB PSU: Be Quiet! Dark Power Pro 12 - 1500W | Monitor: Acer Predator XB271HU & LG C1
https://linustechtips.com/topic/735244-usb-cable-colors/#findComment-9334535
Do you have any suggestions? Today I kept looking at it trying to figure out a way that wouldn't involve unecessary wire cutting or the sacrifice of other devices, and came up with nothing.
https://linustechtips.com/topic/735244-usb-cable-colors/#findComment-9340214
The only way would be to cut it and use a multi-meter to check continuity.
https://linustechtips.com/topic/735244-usb-cable-colors/#findComment-9340310
