what are the chances that every single usb port/connector on my motherboard(ASUS P9X79 PRO) are dead, nothing responds when i connect anything to them
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
https://linustechtips.com/topic/734974-dead-usb-20-mobo/
This related to the XBOX controller? Is the USB controller installed in device manager? Check bios also
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/734974-dead-usb-20-mobo/#findComment-9331267
im unsure wether it is related, but it seems to be point towards the adapter being faulty, but ever since i got the pc the USB 2.0 has never worked and only the usb 3.0 has worked
https://linustechtips.com/topic/734974-dead-usb-20-mobo/#findComment-9331269
Ok well heres the thing, my receiver wouldn't work in the USB 3. only USB 2.0
Ryzen Ram Guide
https://linustechtips.com/topic/734974-dead-usb-20-mobo/#findComment-9331278
ive always had it plugged in on 3.0 and its worked fine
https://linustechtips.com/topic/734974-dead-usb-20-mobo/#findComment-9331285
Lol these controllers, mine stopped working in USB 3 and had to go in the USB 2.0. You tried USB 2.0 front panel header?
Ryzen Ram Guide
https://linustechtips.com/topic/734974-dead-usb-20-mobo/#findComment-9331299
anything related to usb2.0 doesnt work :/
https://linustechtips.com/topic/734974-dead-usb-20-mobo/#findComment-9331303
Is the controller available in device manager? (USB host controller) Check usb 2.0 controller is enabled in bios
Ryzen Ram Guide
https://linustechtips.com/topic/734974-dead-usb-20-mobo/#findComment-9331307
the adapter shows up, but i cant connect the controller via usb since it the usb broke on the controller
https://linustechtips.com/topic/734974-dead-usb-20-mobo/#findComment-9331311
I thought your USB 2.0 on the motherboard wasn't working? You need to diagnose that first then worry about the XBOX controller cause I bet it will work on USB 2.0
Ryzen Ram Guide
https://linustechtips.com/topic/734974-dead-usb-20-mobo/#findComment-9331323
im getting a replacement adapter.
this is my device manager
https://linustechtips.com/topic/734974-dead-usb-20-mobo/#findComment-9331338
Cool, did it work ?
Ryzen Ram Guide
https://linustechtips.com/topic/734974-dead-usb-20-mobo/#findComment-9333335
2 hours ago, stealth80 said:
Cool, did it work ?
nope, pretty sure its the controller at this point :/
https://linustechtips.com/topic/734974-dead-usb-20-mobo/#findComment-9334105
any ideas as to why ALL my usb 2.0 DONT work at all, neither do the headers?
https://linustechtips.com/topic/734974-dead-usb-20-mobo/#findComment-9334164
