I was just wondering if anybody knew of some good reputable thermal pads, I'll be using them on my GPU. Not really sure what I should be looking for in terms of material or thermal emissivity/conductivity, so any help would be appreciated. Doesn't have to be anything top of the line, it's just a straight up replacement of the stock pads, so whatever works.
Thanks in advance.
https://linustechtips.com/topic/734952-reputable-thermal-pads/
42 minutes ago, SageOfSpice said:
any should do im pretty sure they are all the same
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
https://linustechtips.com/topic/734952-reputable-thermal-pads/#findComment-9331099
