Freenom.com help
Go to solution Solved by Granular,
Well, those domains point to different IP addresses.
rcsptt.ga has address 195.20.52.219
panthertechteam.ga has address 195.20.53.51
In the site where you got the shorter domain, you have to either edit the A record for rcsptt.ga to the same IP as panthertechteam.ga or delete the A record and insert a CNAME record instead.
I have a domain, panthertechteam.ga, and I made a shorter domain, rcsptt.ga. I want it to redirect to the first site, but it makes it look like it is its own site. Is there a way on freenom to have it redirect, and not have it just grab the information. Can somebody help me?
i like trains 🙂
https://linustechtips.com/topic/734085-freenomcom-help/
https://linustechtips.com/topic/734085-freenomcom-help/#findComment-9321475
