So I notice that my case occasionally makes these "popping" noises when I first turn it on and play games for maybe an hour in. After that the noise isn't noticeable much as it doesn't do it as often. Even when the PC is turned off after a gaming session, I can hear the popping noises occur randomly in the span of an hour, but it's not really that frequent.
The noise is basically like when something gets stiff and you press down on it and it sort of making a crackling noise.
I hear it mostly coming from the top where my radiator for the H115i is. My case is an Enthoo Luxe Tempered Glass edition.
Here is my full build: https://pcpartpicker.com/list/dNhpVY
Is there anyway to get rid of this or is it normal? I don't wear headphones so it gets quite annoying hearing this.
https://linustechtips.com/topic/733923-case-making-popping-noises/
