I have an Dell Ultrabook that has a USB type c and USB3.0 port. I have something that I am trying to do that requires more USB ports. I currently have an USB type C hub but the application I have says that I need more USB power for the devices. What I am looking for is a good USB type C or USB 3.0 hub that gets it's power from the wall so I have enough power from device. Any suggestion on a good USB hub?
https://linustechtips.com/topic/733766-usb-hub/
Linus just did a video recently on it but for some USB type C hubs you can supply extra power using your type C charger from the laptop as a pass through into the hub.
http://www.juicedsystems.com/BizHUB--USB-C-Multiport-Gigabit-HDMI-Hub_p_46.html
https://linustechtips.com/topic/733766-usb-hub/#findComment-9318395
