Right now I'm deciding between the Noctua NH-L9i and the SilverStone AR06. If somebody has another idea for a 2u CPU cooler I'm open to suggestions though! Thanks for any feedback
Noctua NH-L9i: https://www.newegg.com/Product/Product.aspx?Item=9SIAADY4B02495
SilverStone: https://www.newegg.com/Product/Product.aspx?Item=N82E16835220069&ignorebbr=1
https://linustechtips.com/topic/733697-best-2u-cooler/
Noctua NH-L9x65: It is right in the middle height wise and is a beefed up version of the same NH-L9i that you are looking at.
Cooler Master GeminII M4 & Noctua NF-F12 PPC-3000 PWMStill under the height constraint with a very high performance fan for airflow.
https://linustechtips.com/topic/733697-best-2u-cooler/#findComment-9317713
