Do those two RAM stick sets work together?
Go to solution Solved by Aniallation,
DDR3 and newer RAM will pretty much always work together, even with differences in speed and latency. However, they will all run at the same speed of the slowest stick.
So I currently have two 8 GB Sticks in my PC (those: http://www.mindfactory.de/product_info.php/16GB-G-Skill-RipJaws-VKB-schwarz-DDR4-3200-DIMM-CL16-Dual-Kit_1013799.html), and I'm wondering if there will be any Problems if I buy one set of these (https://www.amazon.de/G-Skill-Trident-16GB-16GTZR-2x8GB/dp/B01MY78EPQ/ref=sr_1_1?s=computers&ie=UTF8&qid=1486294486&sr=1-1&keywords=rgb+ram+ddr4+3200+16+gb) and stick both sets into my MB
Thanks in advance,
Daniel
https://linustechtips.com/topic/733531-do-those-two-ram-stick-sets-work-together/
Thanks in advance,
Daniel
bo, but the speed wil be limited by the slowest one.
They should be pretty equal in speed if they are both DDR4 3200 right?
Yes, you won't notice a difference in real-world performance with pretty much any default DDR4 speed.
"Rawr XD"
