13 minutes ago, Ezkamoz. said:
I'm going to be running an i7-7700k on a Asus maximus ix code with a kraken x62 cpu cooler. What overclock should I expect. Voltages and frequencies of possible. Thanks
It's different on evry cpu how good it comes out of ur box...
https://linustechtips.com/topic/733365-help-with-overclock/#findComment-9314019
Out of the box they'd all perform near enough the same, cause that implies its using the stock settings :P
OP - Can't really help until you get the chip and start trying it.
https://linustechtips.com/topic/733365-help-with-overclock/#findComment-9314051
1.3~1.35v (because these Kaby Babies are F*ing HOT) at 4.8ghz would be my starting bet.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/733365-help-with-overclock/#findComment-9314052
