So I have this PC:
#CPU AMD FX 4300
#GPU RADEON R7 360 2GB OC
#RAM 8GB Kingston HyperX
#MOBO GIGABYTE 78LMT-USB3
#PSU LC Power 600w
I've realised the mistake I've made with buying this PSU and I'm kind of concerned that It would fail at a certain moment and destroy the whole thing,so I went by a nice 50€ deal for a CoolerMaster B500 and would like to upgrade,especially since I'm planning to get 4 or 8 more GB ram. So is it compatible with the Motherboard and GPU and is it a good choice?
https://linustechtips.com/topic/733212-psu-compatible-with-build/
22 minutes ago, lukazec said:
Didn't know that,i thought that certain models have different inputs/outputs,thanks for the info.
22 minutes ago, TAHIRMIA said:
A PSU is universal it is compatible with any modern PC
Some can come with 6 pin some can come with 8 pin. Not all can work with all gpu but yours is fine
