cleaning a logitech g9 ?
Solved by linesma,
I would try some rubbing alcohol. I have the same mouse, and had the same problem. That stickiness is the plastic reacting to the sweat in your skin. It may take a couple of times, but it should remove the stickiness.
Serendipity1344 ·
Posted in Graphics Cards4 -
1
1
5
1
toxic_worper ·
14
1
voltigeurramon ·
Posted in Troubleshooting2 -
2
