Just wondering if there's a way to change the sleep mode flashing light to something else. It just gets annoying after a while, I was thinking about changing it to a glow or some other alternative. I just don't know how it would be done/what would be required.
https://linustechtips.com/topic/732594-sleep-mode-light/
Although I don't have an answer to this I feel your pain. My case LED turns my room into a strobe party every time I put it on sleep.
PCPartPicker: z97 Gaming 5 | 750w Photon | 850 Series 250gb SSD | Phanteks Enthoo Pro | LG25um56-P | Corsair K70 RGB | Asus Strix 970 4gb | WD Blue 1TB | Logitech G502 | i7-4790k | H100i GTX w/ (Noctua NF-F12's) | HyperX Fury Black 1x8gb 1866 | NZXT Hue+ |  ATR2500 | ATH-M50x |
https://linustechtips.com/topic/732594-sleep-mode-light/#findComment-9306817
you could try very carefully taping over the led with non conductive tape or covering the led in sharpie carefully and that should dim it a little
https://linustechtips.com/topic/732594-sleep-mode-light/#findComment-9306857
