Hello guys,
I just bought a LG 55UH615A 4k HDR tv for $500 at cosco. Should I spend half of its price ($250) to have a guy at bestbuy to calibrate my TV, or is there another way to calibrate it to have the "best" quality?
Second problem:
I'm NOT a gamer, but I do enjoy watching Dota2 and CS:GO on Twitch tv. Right now I connect my Asus UX303UA via Monster - Platinum Line 4K UltraHD HDMI Cable and having 200 mbps internet speed from Comcast.
When I watch live stream with 1080p60 resolution on my laptop it runs smooth, but when I connect it to the TV the content starts to lagging and unwatchable (even at 720p30). Only with Live stream tho, youtube videos and netflix and anything else run smoothly. So the problem here is my laptop being too weak, right? Im planning on building a pc with latest i7 and gtx1080 to push all the pixel to the TV (considering i5, but will i5 bottleneck the gtx1080 and im still cant watch the videos?)
Yes Im dumb, and trying to be as specific as I can here, so help me out guys, give me some advices, Im really appreciate it.
https://linustechtips.com/topic/732455-problems-with-my-4k-tv/
Don't pay that guy, that is absurd. Have a look for reviews online theres usually youtube videos of guys explaining what settings they used to get the best settings. Also check out AVSforums.
As for the lagging im not sure what is going on there, if the laptop can run 1080 fine it should run it fine on your TV (your TV will handle the upscaling)
If you're gonna game and can fit the i7 in the budget I definitely recommend it (see my purple text)
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/732455-problems-with-my-4k-tv/#findComment-9305163
That's only true if he's outputting at 1080p, but when he plugs in his laptop it will change the resolution to 4k (native) not just upscale 1080p. He'd have to manually set the resolution back down to 1080p in his display settings.
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
https://linustechtips.com/topic/732455-problems-with-my-4k-tv/#findComment-9305580
Calibration largely doesn't make sense in the home.  Is it a scam?  No.  It's valuable when targeting specific results.  If you are working on creative projects it can be a benefit to have all screens calibrated in line.  It makes sense for a professional theater to be calibrated for uniform viewing.  But in your living room, it's a subjective experience, play with the color settings until YOU like what you see because that's what matters.  What you feel is 'ideal' may not be what the 'correct' calibration is, but what is REALLY correct is what feels right to you.
https://linustechtips.com/topic/732455-problems-with-my-4k-tv/#findComment-9305755
well yes, but he said it even does it @720P unless op is referring to the stream quality rather than the set res, which would mean it purely is down to the laptop hardware
Ryzen Ram Guide
https://linustechtips.com/topic/732455-problems-with-my-4k-tv/#findComment-9306072
I think it is pury down to the laptop hardware like u said, the res is still 1080p native when I connect the laptop to the TV, so I guess time to save for a new pc then....
https://linustechtips.com/topic/732455-problems-with-my-4k-tv/#findComment-9324600
