Do I need premium cables?
Solved by Oshino Shinobu,
1 minute ago, dattharao said:what about premium hadmi or dvi (dual link) cable?
Nope. They just carry a digital signal (though some versions of DVI can carry analogue), so for the most part they either work or they don't. At most, premium cables may gives you some extra protection against cats if they try to chew through some sleeving or something. In terms of picture quality and performance, it makes no difference.
