Hello.
I would like your help.
I have a mechanical disk, that has some bad area (sectors). I would like your help in the procedure that I mark these area
as non usable, and make this disk as a new one, in order to be useful again.
Have you some procedure-steps to advice me? Some page(s) to study and come in result? Something else?
Thank you for your time!
https://linustechtips.com/topic/732151-mechanical-disk-work-again/
Open up an elevated command prompt and type chkdsk as below where the drive to be checked is E:/
Quote
chkdsk E:
https://technet.microsoft.com/en-us/library/dd637756.aspx
Alternatively, you can run the Check Disk tool from inside Windows by selecting the drive again if that drive is E:/, then right click and select "Properties" in file explorer then "Tools" and finally in the "Error Checking" tab by selecting the check now button.
hope this helps
Those who deny freedom to others deserve it not for themselves (Abraham Lincoln,1808-1865; 16th US president).
