9 minutes ago, Microsoft Master said:
So i want to be that guy who looks like he uses the old dell case from the early 2000's and when I take of the pannel they fall to the ground but i have 2 problems it has a hard drive mount of it and a incorrect io shield what should I do?
If you can't pop out the I/O shield, time to get a Dremel tool to do the job.
Also what's wrong with a hard drive mount? If you need a 2.5" internal drive mount, you can get a converter.
https://linustechtips.com/topic/731965-using-old-case/#findComment-9299286
Its from the early 2000's so it has no internal plug in its all done through external wires its just a casing for the drives  Image result for thick hard drive
https://linustechtips.com/topic/731965-using-old-case/#findComment-9299317
You might want to take a picture of the case itself and show it to us.
2 minutes ago, Daniel644 said:
your bigger issues are the proprietary front panel ribbon cable header that won't work with your MOBO.
Nothing a bunch of 0.1" header wires can fix, unless they take some odd voltage.
https://linustechtips.com/topic/731965-using-old-case/#findComment-9299330
your bigger issues are the proprietary front panel ribbon cable header that won't work with your MOBO. you know the ON/OFF switch, reset and indicator lights.
My Header is conected to the mobo and can be removed and this case had 2 disc readers and the front io shield can be removed.
https://linustechtips.com/topic/731965-using-old-case/#findComment-9299342
reset and indicator isn't all that necessary. Just listen to the fans spin up.
lttstore.com
https://linustechtips.com/topic/731965-using-old-case/#findComment-9299343
Get a standard ATX beige case from the 90s. Dell will be full of proprietary motherboard and connectors
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/731965-using-old-case/#findComment-9299409
1 minute ago, Microsoft Master said:
I just like reusing stuff like this it just makes people amazed that people still use stuff like this
I fix computers from this era on a fairly regular basis. Some of them still do fine for basic stuff. I would find a case that at least has an atx format a lot of the dells from then are btx or even more odd.
I am a paid professional, but only when I am at work...and getting paid.
https://linustechtips.com/topic/731965-using-old-case/#findComment-9299441
Ok this i know is one of the larger towers dell made and the funny thing is i still have all of the origional componets but the ports are destroyed like completly and i still have the port covers so you know ALL of the parts are there.
https://linustechtips.com/topic/731965-using-old-case/#findComment-9299456
Can you take a picture of the back and inside? Then I can tell you about how much modding you will need to do.
https://linustechtips.com/topic/731965-using-old-case/#findComment-9299472
