Hello Guys
I have built a new pc, unfortunately it doesnt work. All fans are spinning and all LEDs are on but i cant boot because it says :
Quote
USB Device Over Current Status Detected !!
It also doesnt recognize that i have plugged in a keyboard and that my ram is at 1600 MHz.
I have baught all parts new exept of the cpu, its form my old pc, here is a list of the components:
Intel core I7 4770
Gigabyte GeForce GTX 1070 G1 Gaming
ASUS B85M-G (LGA 1150, Intel B85, mATX)
Corsair VS550 (550W)
Corsair Vengeance LP (2x, 4GB, DDR3-1600, DIMM 240)
WD Blue (1000GB, 3.5")
and a MSata ssd with an adapter
I have allready checked all usb ports for any damage and unpluged the front usb slots but the message is allways the same :
I dont know what to do now, i am sitting infront of my pc now for two days
pls help
https://linustechtips.com/topic/731400-usb-device-over-current-status-detected/
Did you install windows through a USB drive? If so you have to change the boot order in bios to make the new boot drive come before anything else.
Try booting with the front panel USB connectors unplugged.
Edit: misread first post.
Try using different ports for the keyboard.
3600X @ stocke | 5600XT TUF OC @ 1850 | 2x16 + 2x8 RAM 3200 HD | 1tb Samsung 970 EVO Plus | Lian Li 205M | TT Toughpower Grand RGB 850 | throwaway b450 asus mobo | BQ cooler
7 minutes ago, rypax said:
i cant get into the bios. The storage is from my old pc an it already has windows on it but i cant select anythig because i dont get into the bios. Thats my main problem
have you tried every single usb port? Tried a different keyboard?
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
You might have a shorted back USB port. That would be pretty bad but not the worst.
Disregard
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
Try a different keyboard with nothing else plugged in to USB. After that RMA the board.
Black Knight-
Daughter's Rig;
Send it back for refund or replace.
Black Knight-
Daughter's Rig;
Have you tried other keyboards? If every other USB device is unplugged, and multiple keyboards won't work, it has to be the motherboard. CPU and RAM won't cause your USB message and an unreponsive keyboard.
Black Knight-
Daughter's Rig;
  • 2 months later...
