I Need help with my desktop it wont boot still and i dont have any problems with the parts besides the ones that dont work i need help in the main part the motherboard hdd and psu its 850 watts i have problems with  the start up it wont work on my tv and a different tv and my monitor . i need help is it the 2 hard drives they total in 5tb of storage it has a problem with the launching one of the hd is refurbished and the other one is used from my other desktop its 2tb it still has the stuff from my previous gaming desktop (my graphics cards my one of my storage (2tb) the ram , cpu)   . I don't know what the problem is, could it be the hard drive  and where their plugged in at on the motherboard. (computer specs 970 i5 6600k 16gb ram 5tbs of storage (2 hard drives)
https://linustechtips.com/topic/731361-i-need-help-with-launching/
you need to start over. I have absolutely no idea what your problem is, your thoughts are so scattered!
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
21 minutes ago, Totallygamer2017 said:
-snip-
If I'm reading this right, you're trying to boot your new system off of a hard drive with a Windows install from your old system. This isn't going to work because you cannot necessarily take one Windows install and expect it to work in other machine by just switching drives over. If that's not the issue, then please rephrase everything in coherent sentences. You have bits and pieces of information mixed all over the place.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
