Has anyone had a lot of experience with CNC machines?  Are there any recommendations?  Price over performance and other questions like that.
Just thinking about doing some CNC projects and want to make sure I start off on the right foot.
Thanks for all input.
EDIT:
Realized as I was on some other forums, that I should include price.  I am thinking $500 give or take.  But I am all up for creativity.
Edited by TheCamba
https://linustechtips.com/topic/730918-best-cnc-kit/
depends on what you want to do. Any hobby level kits are not going to reliably cut any kind of metal though they can do just fine with wood and some plastics. If you are looking at kits, be sure to avoid any with belt drive axis. You want ball screw linear motion for any kind of cnc work. If you want to machine metal, the minimum i would go with would be something like a tormach pcnc440.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/730918-best-cnc-kit/#findComment-9287998
33 minutes ago, bob345 said:
-snip-
1 hour ago, Doramius said:
-snip-
I am looking at primarily wood working.  Metal would be way on down the line.  If I did metal, it would only be deep enough to engrave.  I figure that would be a different bit and seeing if the drill could support the resistance.
https://linustechtips.com/topic/730918-best-cnc-kit/#findComment-9288341
In that case, i might recommend building your own. For a wood cutting cnc router, there is not really all that much too it and there is a ton of information out there for diy cnc routers. open builds has a pretty nice database of designs.
http://openbuilds.org/?category=cnc-router-builds&id=286
https://linustechtips.com/topic/730918-best-cnc-kit/#findComment-9288387
