Hey guys,
So I'm searching for some upgrades here's my budget: 7565$ ( all are in argentine peso) here are the upgrade plans:
upgrade plan 1:
Samsung Evo 120Gb -> 1700$
Corsair Carbide 400c -> 1800$
Coolermaster hyper 212 EVO -> 1039$
Hyper X blue DDR3 1600 Mhz 8Gb
overall cost: 6089$
upgarde plan 2:
same SSD -> 1700$
case NZXT S340-> 2139$
cooler same -> 1039$
ram -> 1550$
overall cost: 6659$
upgrade plan3:
SSD (same but 250Gb) ->2500$
case (corsair one) -> 1800$
cooler (same) -> 1039$
ram -> 1550$
overall cost 6889$
Basically my question is which on of those 3 plans would be the best or what should I change any opinons?
https://linustechtips.com/topic/730841-need-help-with-my-upgrades/
@TheRandomness or some other moderator please move this to the appropriate subforum, thank you :)
Quote and/or tag people using @ otherwise they don't get notified of your response!
The HUMBLE Computer:
AMD Ryzen 7 3700X • Noctua NH-U12A • ASUS STRIX X570-F • Corsair Vengeance LPX 32GB (2x16GB) DDR4 3200MHz CL16 • GIGABYTE Nvidia GTX1080 G1 • FRACTAL DESIGN Define C w/ blue Meshify C front • Corsair RM750x (2018) • OS: Kingston KC2000 1TB GAMES: Intel 660p 1TB DATA: Seagate Desktop 2TB • Acer Predator X34P 34" 3440x1440p 120 Hz IPS curved Ultrawide • Corsair STRAFE RGB Cherry MX Brown • Logitech G502 HERO / Logitech MX Master 3
Notebook:  HP Spectre x360 13" late 2018
Core i7 8550U • 16GB DDR3 RAM • 512GB NVMe SSD • 13" 1920x1080p 120 Hz IPS touchscreen • dual Thunderbolt 3
Paint flames on your case to make it go faster
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
1 minute ago, SDWdidi said:
sorry man didn't know where to put it :/
Why no problem man :) It happens
As for your question:
Why do you need a new CPU cooler? And what CPU would that be?
Personally, I like the NZXT (based on pictures) a lot more than the Corsair case, but that's a matter of personal taste.
I'd suggest you get a 250GB SSD no matter what case you decide to go with, so Upgrade path 3 would be my pick. 120GB will run out so fast (Been there, done that)
Well atm I have a intel I74790k and yeah I do like more the NZXT case but idk if I could get it with the 250gb ssd (allthough the numer is high i am on a tight budget)
Okay. Have you considered splitting the upgrade into more parts, saving up for the rest in between?
Example: get the RAM and SSD now and save a bit so you can get the case and CPU cooler later?
I've opted for that but the prob is I curently have a lot of problems with w10 (surprisingly ;)) and I get 100% usage (not always) and on bf1 I get lag cause I don't have enough memory and then the case is because the current case is complete shit and need to change it asap
OK, so case+RAM now, the rest after next paycheck?
Besides, from the prices you listed, the NZXT case and 250GB SSD plus the rest makes 7228 pesos. You said your budget is like 7600 pesos.
I wasn't sure (didn't fo the math for that)
