So I recently installed my custom loop, and I had been getting CPU temps of 58c at 100% CPU, I just drained my loop to see what the issue was and it turns out the CPU only 3/4 covered in thermal paste, so I'm naturally thinking this is the cause of the high temps?, could this also explain why the temps skyrocket as soon as the CPU goes to 100% the CPU goes straight to it's maxed temp which is 58c
Thoughts on this?
Gaming Rig:  Case: Modified  NZXT H440 Black/Red | Storage: 512GB Samsung 960 Pro SSD & 3TB WD Black HDD | CPU: Intel Core i7 7700K | Motherboard: Z270 Sabertooth TUF Mark 1 | PSU: 1000W EVGA P2 | Graphics Card: GTX Titan X Pascal | RAM: 32GB G.SKILL Trident Z RGB 3600Mhz | Cooling: X3 RES, CoolStream XE 360 Rad, Gold EK Supremacy EVO, D5 PWM EK Pump, Ice Dragon Nano Fluid 2Litre | Fans: 6x Corsair SP120 PWM Fans 1x Corsair AF 140 | Cables: CableMod Black/Red Braided cable kit | Case Mods: Tempered Glass front panel & Tempered Glass Side Panel (Finished)
Setup: Monitors: Ben XR3501 2x Acer GN246HLBbid 24 | Keyboard: K70 & K95 Vengeace RGB Cherry MX Red | Mouse: Razer Deathadder & Corsair Scimitar RGB | TV: 43" LG 4K Smart TV, 50" Samsung 4K
Laptop: ASUS ZenBook UX310UA-FB097T
Racing Cockpit Setup  GT Omega Pro with TV stand | 52 inch Bush Smart TV | Fanatec CS v2.5 | Fanatec CSL Elite LC | Fanatec P1 & Formula Rim | Corsair Strafe Blue MX RGB
Racing Cockpit PC: Case: Unknown cheap case from Amazon (modified to fit GTX 1080 & Cooler) | Storage: 1TB Samsung 960 Pro | CPU: i7 7700k | Motherboard: MSI Z170 | PSU: 750W EVGA Gold | Graphics Card: GTX 1080 | RAM: HyperX Fury 32GB 2400mhz | Cooling: Hydro 100i | Fans: 4x Corsair SP120 PWN fans | Cables: Standard PSU Cables | Case Mods: Making room for GTX 1080 & Cooler.
https://linustechtips.com/topic/730482-cpu-temp-with-custom-loop/
Thoughts on this?
What CPU is it? 58C isn't a terrible temp for the majority of chips, what does your loop consist of? The paste won't have helped, but it won't have caused too much of a difference
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
I7 7700k, not overclocked, it's just CPU loop, I know it's not terrible but I was using a H115i before this and it was maxing at 48c
Edit: As I said it was only 3/4 covered, so there was quite a bit of metal on metal action, surely that would drive the temp up massively?
When did you put this together? Did you let all of the air bubbles escape? Are you getting enough flow through the loop?
What does your loop consist of? Rads, blocks, pump, fans? It wouldn't have made a massive difference, the heat would still be pulled from the chip, it's just not as efficient, id expect only 3-4C difference
Ryzen Ram Guide
360mm rad, CPU block, pump, res, all the bubbles escapes but it was hard to do that when the res was sideways, what could it be if not the thermal paste?
anyone? does position of the loop make a difference?
No. The ONLY thing that is important regarding the loop position is that your reservoir is above your pump, and this is only important so that when filling the loop the liquid goes to your pump you don't run your pump dry.
If you didn't have all the die covered with thermal paste then this is likely to push your temperatures right up. Reapply thermal paste and get back to us if the temperatures are similar.
I will do, just stripped everything now rebuilding with different layout
I was just thinking,would it be stupid to fit the 360 rad externally?
No, I have an internal and external rad. Just do make sure you have atleast one fan in your case though, you do want some airflow over your ram, mobo and drives.
Honestly those temps aren't terrible, my 4790k @ 4.7ghz runs around 50C whilst gaming but I have 240 thick + 360 XT45mm rads. Also what fans are you using? The fans on the Corsair AIO's are usually quite loud but move a lot of hair. That paste won't make a huge difference I guarantee it, as I said earlier 2 - 4C I reckon, infact i'm sures theres a vlog somewhere with someone using toothpaste as a thermal paste and the difference wasn't as vast as you would think.
I wouldn't worry about moving your rad outside the case, your temps are perfectly fine, and its not worth the cosmetic downgrade (imo) of having the rad mounted externally. Also check your board isn't throwing more volts down the vcore
Ryzen Ram Guide
Finished the rebuild. and I'm still getting 55c, this layout has 7 extra fans the other layout had 3, which was the radiator fans, how can it be so hot? I know it's not a bad temp, but how do I justify spending £400 on a custom loop if my £110 AIO does a better job? is the cosmetic of a custom loop really worth that £300 and 10c degree more than the AIO?
what fans are they? same for and blocks?
Ryzen Ram Guide
XTX 360 Rad 64mm thick, EK Supreme CPU block, and EK PWN Fans
Got to say I'm pretty pissed off if I'm honest, it's worse than it was last time, I'm getting high 50s now just for GTA V at 50% CPU usage, and 41c at idle, this is beyond ridiculous, if I can't sort this out i'm going back to AIO no way can I justify spending £300-£400 more for a worse performing custom loop, my AIO was 37c in GTA V, this is 53. that's 16c MORE, the CPU temp spikes to 55c almost immediately and stays there.
Did you check the voltages? 41C idle seems high, mine sits at 30C right now and its in the loop with a 1080GTX and the motherboard VRMS (admittedly I have 2 rads). Are you certain your you have flow? What speeds are the fans running when stressing the CPU? Can you post a picture of your loop ? I'd like to help get this sorted, hate seeing disgruntled custom water coolers!
Ryzen Ram Guide
Not sure what you mean voltages, my CPU is not overclocked, I'm sure I have flow? I got a manual and it told me which way to attach the tubes so I did that correctly?, I'm not sure what speed the fans are running how do I check that?
Sure, it'll be a bad picture though as my camera is broken
Edit: Can't find my phone mate it's 2 am and I'm knackered, but if this helps: NZXT 440 case, with the 360 Rad on the front, Pump on the case floor next to rad with res attached to the radiator, then obviously CPU block
You not have a phone? A custom loop should not have higher temps than an AIO, unless something is wrong somewhere. Some motherboards will have the vcore setting default as auto, which will cause it to add voltage as the CPU boosts, making the CPU hotter. The fans will be controlled via the bios if theyre PWM, there should be a setting in there to plot fan speeds vs cpu temperature - aka as the CPU heats up, the fans speed up, I have my pump on the same config. Quickest way to check for flow would be to crack the drain with the PC running (into a jug or something lol!)
Ryzen Ram Guide
Yeah I do have a phone but I'm tired as hell and can't be arsed to find it, I don't know anything about BIOS but I dont understand why voltage would go up if I'm switching from AIO to custom loop? I haven't touched BIOS so.., also I did check BIOS today and I never saw anything about vcore or even fan speed,
Do I have the flow right?
I would look at some guides on setting up a bios for watercooling. Can you explain to me how you filled your loops please, like exactly :)
Ryzen Ram Guide
Guides? what do you mean guides? what does BIOS have to do with WC when I can go back to AIO right now and see 10-20c less without doing anything to BIOS? & erm ok, Fill res, turn on pump, turn off pump so theres about 1 inch of fluid, rinse and repeat till res fluid no longer goes down
Ok that tells me you have flow :)
Because you need to set the fan/pump curve profiles for your system. Theres no way your temps should be higher with a custom loop. Can you remember the exact model of your pump and fans? OH and did you check the jet was correct for the 7700k when you fitted the block? Theres different jets for X99 and the others. I'm gonna guess you definitely removed the plastic cover from the block? (not to insult you, weve all made some silly mistakes, infact I did it briefly with my old rig) What paste did you use?
Ryzen Ram Guide
https://www.amazon.co.uk/EK-Water-Blocks-EK-KIT-X360/dp/B00LXIRASS, thats what I used, the jet? is that the thing inside the CPU block? I left the one that already came with it inside was I supposed to switch it out? I'm using B150 Mobo (shh lol), Yes I'm sure the plastic is removed, I used the paste that came with it, then I used Arctic Silver MX-4
Ryzen Ram Guide
2 minutes ago, stealth80 said:
Can you tell me what you want me to see here? doesn't make sense to me?
Step 2 on the instructions, look at the jet plates, they should be changed depending what CPU socket you are using
Ryzen Ram Guide
