Hi! I am getting a new keyboard, and I am choosing between mx blues or Razer greens. I really wanted the mx greens, but they are nonexistent in my location, so those two will have to do. I have found some keyboards in my price range and they all have either blues or greens. Those 3 choices are the razer Blackwidow (Blackwidow T2 2014) with green switches, Apex M500 with blue switches, or the Strafe with blue switches. Which of these 3 should I go with? The apex is the cheapest and the blackwidow is the most expensive. They all have the same layout and stuff, but I heard that the Razer switches have a rather short lifespan / aren't as durable as they advertise. Out of these, which one should I chose? Thanks!
Edited by colonel_mortis
Links removed - the specific site that was linked to has been blacklisted
https://linustechtips.com/topic/730279-what-switches/
I like Razer Greens since they feel like MX Blues but aren't as loud. If you don't mind the noise of the MX Blues, go for the one that looks the best.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/730279-what-switches/#findComment-9280947
