Are these temps safe?
Solved by Godlygamer23,
1 minute ago, sakibsadmanshajib said:I'm thinking of using this overclock for like everyday use. Once I heard someone say 70C is too hot for a CPUf ro daily use. Plus I'm running my CPU at 1.25V all the time. Is that Okay?
The lower the temperature, the better. But 70C is fine for Intel's CPUs. In regards to voltage, it's best to reduce it as much as possible, and if you use Adaptive voltage in conjuction with Balanced power mode, you can make that happen.
