Linux Mint XFCE Help
Go to solution Solved by Gas_Mask_,
Realized I had no swap partition... Even the experienced make dumb mistakes sometimes right? I mean common, we're on the Linus Tech Tips forum
So I'm running LM XFCE 18.1 (just upgraded). Every time I try to hibernate it doesn't work. (Had this problem since before the update, so that has nothing to do with it.)
So I've tried multiple different kernels to try and fix it, and nothing. The usual things that happen when I try to hibernate are: my pc will just shut off, it will sort of hibernate, then when i wake it up either freeze and then restart or just kernel panic, just straight kernel panic, it just locks the screen instead, it will just shut off, or it will restart.
I need hibernate for certain things, so this is a problem.
(Pardon me if this is not the place to post this, I couldn't think of anywhere better (and people have gotten mad at me for double posting before))
P.S. I'm running of a USB drive if that helps. (not a live disk, I actually have LM installed and running off a flash drive)
--Gas_Mask_
https://linustechtips.com/topic/729521-linux-mint-xfce-help/
Is there enough space on the flash drive to store all hibernation data?
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/729521-linux-mint-xfce-help/#findComment-9273242
I'm not sure how much data that exactly would be (I assume not a whole lot though, because it's just a ram dump (and I've got 8gb of ram)), but I'm running off a 32gb usb, with over half of it free.
--Gas_Mask_
https://linustechtips.com/topic/729521-linux-mint-xfce-help/#findComment-9273390
