Just wondering, which type of monitor will be the best to get LED or TFT-LCD. (4k monitor) and whats the difference between them both,
These 2 types belong to these monitors: Philips 288P6LJEB (tft-lcd) and Samsung U28E590D (led) .  would also appreciate if anyone can help me decide which one is better to get.
Thanks
-John
https://linustechtips.com/topic/729392-led-vs-tft-lcd/
You are describing 2 different technologies. LED is the back light, TFT-LCD is the display. Both are used simultaneously. I would go with the Samsung monitor.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/729392-led-vs-tft-lcd/#findComment-9271815
They're both LED.
Only long ago you would have cathode vs. LED monitors.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
https://linustechtips.com/topic/729392-led-vs-tft-lcd/#findComment-9271818
TFT-LCD monitors are LED monitors unless they're pretty old, in which case they could be CCFL (Cold Cathode Fluorescent Lights, they'd be thick)
LED is simply the backlight, LCD is the display technology and TFT is a technology applied to pretty much every LCD panel since 2000.
https://linustechtips.com/topic/729392-led-vs-tft-lcd/#findComment-9271834
