Years ago when I was exploring SEO I built a portfolio website for a customer that would take a HTML template and a config file; then generate an entire site with static web pages with a bash script. What I did was a one off experiment and i lost the files. I'm wondering is there any content management or site builder out there that is open source, takes a template and config file as input, then generates static web pages?
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/728281-web-site-builder/
Not to my knowledge.
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
https://linustechtips.com/topic/728281-web-site-builder/#findComment-9259889
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/728281-web-site-builder/#findComment-9260673
Could it be you're looking for Jekyll? It allows you to put most of your data in a config file, then create a template, write some posts, run a command, and it will generate static pages from all of the content. If you're looking for a place to host it, use GitHub Pages, which simplifies the process by compiling using Jekyll for you when you git push, then is hosted at https://username.github.io/repository-name (free SSL certificate, and you can apply a custom domain if you want). GitHub Pages is completely free, forever.
˙ǝɯᴉʇ ɹnoʎ ƃuᴉʇsɐʍ ǝɹɐ noʎ 'sᴉɥʇ pɐǝɹ oʇ ƃuᴉʎɹʇ ǝɹɐ noʎ ɟI
https://linustechtips.com/topic/728281-web-site-builder/#findComment-9265502
